Privatewrench
- 19
- 18
- Kentucky
![20190915_101127.jpg 20190915_101127.jpg](https://www.steelsoldiers.com/data/attachments/532/532768-f79961abbb87943fdbaf1c9e816af459.jpg)
The lower edge (end that attaches to truck) of this hard top that I'm cleaning up to paint and put new weather seals on has the metal skin pulling away from framing. Pretty much all across the bottom section. It's not completley pulled away. Its still atached, but the very edge, as you can see is.
I'm trying to figure out my best course of action to fix this. I can run a weld bead across it, then gring it smooth and paint. Or, maybe easier, use JB Weld across it. Or easier yet, clean it up, convert the rust, paint, then caulk the crack to keep moisture from getting up there.
Anyone out there have a similar repair that worked for them, or advice on the best option.
Thanks in advance!
