Modiconman
- 27
- 8
- Richmond, VA
Rusty,
I finally have completed my auxiliary tank installation using your design as a guide. I used the motorized valve that you suggested and it works great! I mounted it under my heater box on the drivers side fender. I mounted my check valves on the inside of the frame rail near the primary fuel tank and ran the line to my aux tank across the cross member. I also mounted my "tee" connection for the vent line there too. I used copper tubing except for the ends at the fuel tank and the valve, where I used stainless steel flexible lines for ease of installation. I mounted my switch in the same empty hole on the dash as you did! Except I mounted mine "sideways" to differentiate between the left (Aux) tank and the right (primary) tank.
