- 1,450
- 126
- 63
- Gray, GA
Eh...why you gotta bring up old stuff? I'm back quiet, lol.Those in your shop so you can look behind the stacked boxes for those 10,000 drain plug gaskets that are MIA?
I just checked and the 30si with transformer rectifier is available. My cost is a little under $300 new so you have the same money in your setup. If you are going to be running a lot of 24 volt equipment you are better off with a 24 volt alternator.Yea i saw that thread a few weeks back. I was able to nag almost a dozen of the Cummins 24v equipment alternators for really cheap awhile back. So i will only be in it $300 for the alternator and the equalizer. The 30si duals arent common by no means
Can i ask what part number are you using? The delco 3603854RX is an obsolete unit.I just checked and the 30si with transformer rectifier is available. My cost is a little under $300 new so you have the same money in your setup. If you are going to be running a lot of 24 volt equipment you are better off with a 24 volt alternator.
Its a clone, I noted that in my thread. WAI 7256N, you may also find it listed as WPS (World Power Systems) which is a WAI brand. I did a quick google search and came up with 4 or 5 different listings.Can i ask what part number are you using? The delco 3603854RX is an obsolete unit.
Thanks. I was using the Delco number to find the clone equivalent. The wilson built unit is $320 thru napa if you have an account. Doesnt seem too bad.Its a clone, I noted that in my thread. WAI 7256N, you may also find it listed as WPS (World Power Systems) which is a WAI brand. I did a quick google search and came up with 4 or 5 different listings.
Dont think so. its got a homemade bracket on it. and the AC is a Visionaire out of Ft. Worth. It is non adjustable and not a Red Dot unit.I thought that A/C unit was another RRAD disaster?
If you remember, the 24 volt side of the alternator was just to charge the starting series 24 volt batteries. The "Top Charger" that was on my original alternator was made by the company I use to work for. I knew the engineer that designed it and he suggested the transformer alternator. The "Top Charger" was only rated at 10 amps and was a compromise at best. The wire from the alternator as you have noticed is only good for 10 or 15 amps.Welp. went ahead and figured the alternator issue out. Since someone is a complete moron and installed a 24v AC unit in this truck that pulls around 16amps on max blower. Along with the compressor pulling some amps. Basically the reason I am going to assume that this truck was put out of commission was because it was killing the batteries in the summertime and they could not figure out why. The AC was installed in July 2014 around the time they said it was parked. So yeah. we are going to go with that..... Threw a 30Si with the transformer on it that Tow4 suggested. and it can't even keep up on 24v with the AC on high really. Dash gauge drops to 23.8 at the starter switch reading and battery/alternator are both reading 25.7 so it is struggling.
So the choices will be to just run the AC on 12v and rewire it or go to the 100amp 24v alternator and the equalizer. Or swap the AC unit out for a 12v MCC unit.
Alternator wires just aren't big enough to sustain the power draw either.
Always something but just retarded that they used a 24v unit on a predominantly 12v truck.
Off to my next quest of crap for the day.
Yeah. the 24v ac thing is a real drag on it. Why the other day when i left the GA rally it was just killing the 24v side since I had the AC running to keep the windows unfogged. and that drug them down pretty bad.If you remember, the 24 volt side of the alternator was just to charge the starting series 24 volt batteries. The "Top Charger" that was on my original alternator was made by the company I use to work for. I knew the engineer that designed it and he suggested the transformer alternator. The "Top Charger" was only rated at 10 amps and was a compromise at best. The wire from the alternator as you have noticed is only good for 10 or 15 amps.
I guess the question is would it be better to change the alternator to 24 volts and run a heavier 24 volt wire, install the equalizer etc or change the AC to 12 volt. I agree with you, the person that installed a 24 volt AC didn't know anything about the truck.
Nope not a RRAD install.Dont think so. its got a homemade bracket on it. and the AC is a Visionaire out of Ft. Worth. It is non adjustable and not a Red Dot unit.
Yeah saw one on ebay for around $375 new in the box. pretty cheap actually.Nope not a RRAD install.
Remember when during the Gulf Wars, the army came out with a version of the Red Dot HMMWV A/C unit for the 915s. It was 100% 24 volt including those two pancake fans. DUH that promptly burned out all the transformer/rectifier alternators on these trucks and led to the alternator upgrade kit that is similar to the HMMWV.
