M1028A2 acquisition
HASSON1911
24
roseau/mn
Just unloaded my M1028a2 she fires right up on the first crank and purrs right along. First step is starter relay modification followed with manual glow plug mod. Next it's off to the body shop to cut out the rust and repaint. $4800 how'd I do?
I had plans for a 6bt swap but after discovering their rarity she'll be kept relatively stock with a possible exception to a lift and tires.
HASSON1911
24
roseau/mn
As a backup, I didn't know about new cards, I just have read about the plugs staying on so I was going to tap the blue wire with a momentary switch while keeping the rest of the system stock.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Looks great. The other mod to consider is bypassing the GP resistor and running the glow plugs from a 12V source. Keeps the cascading effect from destroying your remaining glow plugs if one fails.
MarcusOReallyus
820
Virginia
Some folks here consider that heresy. Some of us consider it a good idea. I have mine set up that way. If the card fails, I'm good to go.
HASSON1911
24
roseau/mn
That's my view to, my understanding is pushing the button with a functional card it works normal but if the card ever goes out it should still work just without input from your sensors, am I understanding that right.
Also looking to just upgrade the gp solenoid on the firewall to an st85 to get ahead of the inevitable repairs of a 30 year old part failing.
Sharecropper
1,261
Paris KY
All of the improvements in the above threads need to be done. However one of the most useful upgrades I’ve done to my truck was to replace the rear drum brakes with discs.
MarcusOReallyus
820
Virginia
If you have a working stock system, no need to use the button at all, unless the stock system fails.
