A1R Warning about gauges
m-35tom
223
eldersburg maryland
If you have an A1R do not try to test the voltmeters on dash. They are not voltmeters, they are indicators driven by CAN data from a ECM or ECU. Do you know where that unit is located in the truck??
Reworked LMTV
1,182
TN
I can read these signals with my Picoscope if it is CANBUS. If there is no signal, the whole board typically gets replaced.
Reworked LMTV
1,182
TN
I have never looked at one on a military vehicle, but usually there is a central CPU and small cpu's in various aspects of its operation. Look for a box that is similar to the C7 or 3126's ECM. The box may be heavily shielded, if it is EMP proof. In a car with CANBUS, for example, the operation typically done be a relay is taken over by a small cpu's in each door, or truck, or whatever you want to control from the central cpu. It allows much greater flexibility in functions than just on off. If a board goes out, it's typically expensive. Typically the whole board is replaced since it is SMD.
In an A1R where does the signal come from?
Reworked LMTV
1,182
TN
Oh ok, so he is just trying to get the speedometer working. Thought he had a dead CPU board.
Cat can log into the ecm to make changes to match the speedo to the hs gears.
m-35tom
223
eldersburg maryland
NO, I was just saying that the VOLTMETERS on the dash were databus. A voltmeter!! WHY. So I can calibrate the voltmeter with the scan tool maybe?
But the idea of changing the speedo through the C7 engine ECU gets my attention since I am soon putting 3.07 diffs in and I have the CAT scan tool and ETM
And I plan to repair the voltmeter, it is just smd, no problem. That's what I do.
Reworked LMTV
1,182
TN
So if the volt meters speaks CANBUS, then the whole system is CANBUS. Seems a bit overkill to canbus a volt meter, but it does not really surprise me. Now that I think of it, if a had a truck with an ECM, I might carry a pre-programmed spare. My experience with ECMs has been not great. Don't know anything about the CAT ones and reliability. SMD repair can be done with a heat gun and a microscope, as you know. No biggie, if you can trace the signal and find the bad part or look for burned parts on the board. Wonder why it died.
NO, I was just saying that the VOLTMETERS on the dash were canbus. A voltmeter!! WHY. So I can calibrate the voltmeter with the scan tool maybe?
fuzzytoaster
3,524
Fort Worth, Texas
In reality is it not in the allison trans ECU?
When I took my 3126 ECM in to CAT a year ago we walked through the settings. There's a field for the gear ratio that will change the speedometer. I'm setting up a CAT ET laptop to play with these things instead of paying for a tech's time. I bet there's more we can play with in there.
