rcamacho
- 914
- 93
- Bainbridge Island Wa
Front caster is way off and will need correction for stability. Rear Camber is still positive, remove some shims?Good evening ,
I went to a local auto shop to get the Toe adjusted. My 1989 M 998 Humvee would not fit on there machine as the Humvee was to wide. It was recommended that I go to a Firestone as they have a full size alignment machine. I did and my Humvee was able to fit on their machine. Had 4 wheel toe set only. No cast or camber. They told me that specs would be based on a 1992 - 1997 Hummer 1. No Military Humvee of any year would come up in their system. Attached are the specs before and after. As long as the specs are close to the Hummer 1, I should be in good shape. You can see how far the rear Toe was off comparing both the before and after. Cost would have been $79 one time or $179 - 10% Military Discount for the life time alignment. I went with the lifetime. Thank you all for all for all of your help and suggestions.
