- 115
- 120
- 43
- Los Angeles/CA
My M1009 leaks slowly from the rear main seal, and I want to fix it. I had a 350 SBC with a 2 piece rear main do the same thing, and I ignored it for 10k miles until it suddenly spat all the oil out on the road. So I'm trying to not make the same mistake with the 6.2 in my CUCV.
I want to do oil cooler lines and the rear main together during my next oil change. Is there anything else I should do while the pan is off, like maybe the oil pump?
This is a good running truck with unknown mileage. I hear a lot of people say to change the harmonic balancer and timing chain. My balancer looks fine and it seems to run fine (no obvious timing problems), but should I do them anyway? I would probably change the front crankshaft seal, water pump, timing chain and harmonic balancer together if I am going to take it all apart. Or should I just do the rear main now and wait for the water pump to go out before I start messing with the front of the engine?
