3700 SP Overdrive?
94
39
San Diego, CA
Vehicle is a 2007 M1083 with CAT C7 and Allison 3700 SP. I already have 307 gears installed but would like to reduce RPMs even more on the highway. Is it possible to add an overdrive to the transmission?
Sent from my SM-N975U1 using Tapatalk
Reworked LMTV
1,166
TN
I don't think so. This is definitely a Alison question. Might be much less hassle and cheaper to go with a set of larger tires.
94
39
San Diego, CA
Thanks for the reply. Yep, looking at 1400's. From what I've researched that's the largest size possible without lifting the truck or cutting wheel wells to avoid tire rub or limitations.
coachgeo
3,390
North of Cincy OH
Presented this question to an Allison Guru who ownes an Allison rebuild and parts supply company with experience in these transmissions. Answer is basically no.
sure one could custom make a gear...... but still would be no go cause the changes would set off a firestorm in the software and put you into limp mode. Now a whole rewrite of software would be required...... and that is all proprietary software and would light of legality firestorm
94
39
San Diego, CA
Thanks! That's what I needed to know.
94
39
San Diego, CA
The top 2 gears in the Alison core are already overdriven, but the fixed gear reduction in the transfer case cancels that out... you really want to do this in the axle/wheel area anyway to lower driveshaft RPM...
Thanks for the reply. I have the high speed 307's in the axles. Looking at 1400s for tires. Any other suggestions to get those RPM's down?
Reworked LMTV
1,166
TN
Honestly, these truck don't handle that well at higher speeds. Roll overs are known to be deadly with these vehicles. Saw one article recently. I know it is not what you want to hear, but driving slower isn't always a bad thing : )
94
39
San Diego, CA
Totally agree, but high speeds isn't my motivation. It's low RPMs to reduce wear and tear on the engine at reasonable speed. I don't plan to exceed 65mph ever.
