Compressor pressure relief valve
HDN
5,548
Finger Lakes Region, NY
Is that the same valve as what's supposed to be on the compressor? The A3 is supposed to have one at the tanks too, but I'm not sure it's the same part number as the one to put on the compressor.
Floridianson
2,531
Interlachen Fl.
Are you talking about the compressor control? Cats motors had them mounted on the compressor and A2 were on the firewall if I remember.
HDN
5,548
Nope, I'm talking about a safety relief valve. The A3s had a MWO for installing a tee at the compressor outlet with one side of the tee getting a relief valve. I imagine this was done to add redundancy to the existing air safety relief valve mounted to the tanks under the truck. Maybe it could get corroded from road spray and malfunction?
I'm in the process of getting parts, but I haven't found a part number yet for the valve or the tee.
davidb56
1,238
Bonners Ferry Idaho
when Im under the truck, I pull the relief valve "ring" occasionally to make sure the seat isn't stuck. As far as a compressor check valve, My AD9 air drier I installed has one built into it. I have no clue why the A3 has two relief valves.
