I was a USAF loadmaster that loaded and airdropped HMMWVs. We were told that we were NOT to use the wheel brackets as tie down points at all! We could only use the frame mounted tie down points at the front and rear of the HMMWV.There is actually some debate about those brackets, but the normally acceptable answer is they are used for a type of self recovery using a rope/line and a bent metal bar, to act as a winch.
The other answer I've seen is for tying down to skid pallets when being air dropped or for rail transport, but I can't find anything to back up that idea.
There have been multiple threads about them if you want to read up on them, but here's one of the first that comes up in a search for "HMMWV Wheel Bracket"
Humvee Wheel "winch" Self Recovery
https://www.youtube.com/watch?v=00g8pslE2MQ I thought those brackets were for tie downs? Any one out there also use them as self recovery (for those non-winch users)? They seem like they would be a pretty simple way to include a self recovery system without the added system of an...www.steelsoldiers.com
Great information! Thanks!I was a USAF loadmaster that loaded and airdropped HMMWVs. We were told that we were NOT to use the wheel brackets as tie down points at all! We could only use the frame mounted tie down points at the front and rear of the HMMWV.
This attached diagram shows how the wheel mounted points are used...
That said, I have seen a similar diagram that suggested the points could also be used for tie down. So, I think the debate might be because the approved uses of those wheel mounted brackets has changed over time.
What's a "doubler"?Its for mounting the bracket that holds the Drivers Vision Enhancer sensor.
The tan bracket on the left side of hood is the doubler installed when they cut the hood for the DVE cables.
On feb 25th you asked { What is that hole for in the middle of my windshield retainer? }.....Thank you, but I'm asking about the small bracket(s) on the A pillar, not on the hood. One member said it was for a mirror mount. Thanks Everyone!
Thank you very much! So, I'm assuming that the the yellow question mark bracket is a "doubler" that has to do with the DVE system.
No...doubler is on hood....Don't know what yellow thing is.Thank you very much! So, I'm assuming that the the yellow question mark bracket is a "doubler" that has to do with the DVE system.
