charlesmann
- 713
- 93
- Temple, Tx
iv got a leak on my winch motor, out of something that does turn. not sure what it is (has a male sqr drive head on it), but i have tried to adjust it, counting half revs from 1 direction, back to where it was, then the other direction. but its still leaks and is worse (as it should be intros case) when crane/winch hydraulics are operating. i would much rather replace the o-ring, than rob from my other truck, even though that is what it was bought for. here is a pic of where it is leaking from. if i can find out the manufacture and the manufacturer and manf. p/n for the winch, i could at least look at replacing the o-ring before robbing my parts truck.
TM IPC p/n is 2375388 and nsn 4320-01-320-4744
there is no IPC that i know of (maybe a depot level (thought i had all mm and parts manuals) mm and parts manual) just for the winch motors for front, rear and crane.
there is a data tag, partially visible behind right hyd line. but i can't feel any stamps/engravings that would indicate it anything. no other data tags are on the motor.
if by chance, someone does know the o-ring part number, that would be great, but what about a mm for disassembly and reassembly?
