Secondary side air leak
EO2NMCB
23
DeSoto, MO
Truck is a M927 non abs. I can hear air leaking from the air intake. When I depress the treadle valve the leak goes away. I've checked break cans, Q2 Valve, valve under the step on driver side, no leaks into the vent lines and PPV valve, service rear glad hand had no leak. What am I missing? Tried downloading P2P could not get it to work. Only Secondary side is leaking, Primary side is fine.
EO2NMCB
23
DeSoto, MO
I found my problem, I started at the vent lines from the air intake. Turned out to be a relay valve on the front drive axle.
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
You answered your own question. Treadle vakge. It vents to the intake to release pressure. Lowest hose for the treadle valve in the firewall is the vent. Remove it and see if you have air there with the pedal not depressed
Your relay valve for the front tandem axle you mean?
