- 249
- 254
- 63
- Grove, Oklahoma
I recently bought an M1009 that will need a great deal of work. I have been plugging away at it, a little each day. I noticed a few things that I wasn't quite sure about, so I took some pictures. If any of you can provide some insight, I would greatly appreciate it.
This clip is attached to a glow plug. Unfortunately, most of the wires have been cut. I would like to replace these wires and clips. Does anyone know where I can find these clips.
..![Glow Plug Connector.jpg Glow Plug Connector.jpg](https://www.steelsoldiers.com/data/attachments/552/552196-1a6bffefeb10fdf9c6eee960d8352418.jpg)
The picture below shows a tiny wire that exists between the upper (Positive) and lower (Negative) terminal blocks located on the fire wall. What is this wire for?
![Small Wire.jpg Small Wire.jpg](https://www.steelsoldiers.com/data/attachments/552/552197-4d07ff33607428cd076d467d424581d3.jpg)
Injector Return?? In the picture below, I put a couple of red arrows pointing to what appears to be small rubber hoses between the injectors. I am guessing that these hoses are part of the fuel return system. Is this correct??
![Injector Return.jpg Injector Return.jpg](https://www.steelsoldiers.com/data/attachments/552/552198-bd733f065efc2dbbfe175aaa3d8d39d4.jpg)
Final picture for the night! The picture below shows a small wire clip that holds the red wire from the battery to a block on the mounted on the firewall. Most of my clips are missing. Does anyone know where I can find these clips? Are that alternative clips available? Any info would be a great help....
