Which bottle jack?
MTVR
761
Waco Texas
I was somewhat fortunate in that my MTVR came with the flat steel jack base, wheel chocks, and the long threaded hold-down for them inside the passenger side steps... I do need a bottle jack.
What would be a good choice (and a good value)? Can I power an air over oil one off of the truck?
Elijah95
Certified Rookie
1,240
1,215
Georgia
I use a 20 ton from harbor freight and keep 10 4x4 pressure treated blocks 12” long for adjusting height before jacking.
I prefer my manual jack over an air powered for reliability sake
Elijah95
Certified Rookie
1,240
1,215
Georgia
Don't the air over oil ones have a manual handle too?
Yes, but if you’re going with harbor freight flavor steer clear from the air jacks they are prone to leaking past seals even when on the shelf. I’ve had my 20 ton for 3 years now and I’ve learned the 30 seconds you save jacking just simply isn’t worth it imho
MTVR
761
Waco Texas
I'm inclined to take your advice on that, Elijah. Thank you.
Elijah95
Certified Rookie
1,240
1,215
Georgia
Now if you can find a reputable brand name air jack by all means it may be worth while! I can only vouch for what I’ve seen, other experience may vary.
And yes I keep all my tire changing and assorted tools in that storage box. Beware though, that box isn’t sealed and if water gets on your floorboard it will enter the box as well.
zebedee
conceptualizer at large
894
Central NY
I have a couple of 20 ton bottle jacks spare ( they are BII for an M916) and are US made.
98G
Former SSG
4,825
Carry two....not just one and cribbing.
Consider - you have to start off low enough to get under a flat 16.00. And you have to end up high enough to fit an inflated 16.00. Most jacks wont have enough travel to do this.
And you can't add cribbing once the truck is on the jack.
MTVR
761
Waco Texas
I was kind of visualizing the process and thinking the same thing. Maybe a pair of regular 20-ton bottle jacks would be good...
  • Like
Reactions: 98G
Elijah95
Certified Rookie
1,240
1,215
Georgia
Or if you get resourceful some roadside scavenging/additional wood blocks will allow you to drive blown tire up onto it, then insert jack and cribbing to obtain proper height for new tire. Owning any MV requires being resourceful and a strong determination to “Adapt and overcome any obstacle” otherwise when you break down you’ll be paying a HEFTY tow bill $1000+ along with a few thousand on repairs. I’ve never paid anyone to work on my trucks period
simp5782
Feo, Fuerte y Formal
9,507
Mason, TN
Then again I'm lazy. I say the any reason to need a bottle jack means that the wrecker can lift it easier.
  • Like
Reactions: 98G
