- 1,967
- 1,297
- Paris KY
As many of you know I am assembling a P400 6.5 engine to replace the OEM 6.2 in my M1028. Details can be followed in my rebuild thread link below.
My question is, I am installing a mechanical fuel pressure gauge immediately upstream from my injection pump, between the pump and filter, and was wondering what a normal fuel pressure should be. I plan to primarily furnish fuel to the engine via the OEM mechanical fuel pump, however I have routed the fuel supply line in such a way that I can swap over to an electric fuel pump if necessary, or if the OEM pump becomes defective while out in the boonies. The P400 engines were designed to be used in the upfit HMMWV's which would have been turbocharged. I do not plan to turbo the P400, however that's an argument for a different thread. The P400 is rated at 250 HP turbo'd, so I had Huckstorf Diesel set the initial fuel delivery of my rebuilt DB2831-4911 for 200 horsepower. John Hucksdorf stated that I would be able to turn the fuel up or down on this IP to match the pump with the power of the engine. My goal is to provide the exact amount of fuel the engine can burn efficiently, no more or no less. Too less fuel would be wasting the potential of the engine, and too much fuel will be sent out the exhaust as un-burnt black smoke and wasted money. So what I am looking for is a starting point for fuel pressure as the fuel is entering the IP. I will monitor the fuel pressure gauge when the engine is under full power to make sure sufficient fuel is being delivered.
Thanks in advance for knowledgeable comments.
