What are you using to seal up the turret cover?
spankybear
977
WA
I see the TM calls out a aerospace polysulphide sealant to seal around the top and screws. I was wondering what you people are using?
Thanks
Suprman
706
Stratford/Connecticut
I use loads of silicone. Around the hole before I put the cover on. Around the bolts before and after I tighten them down. Around the lip. I remember that aerospace sealant. You had to mix the tube by hand and it took a long time. We used it on aav and lav antenna installations.
tennmogger
556
Greenback, TN
Nylon or other 'smashy' washers under the bolts will seal those. I had a persistent leak and it was a bolt leak. Drove me crazy to find it. The plug is sealed with DOW U-428 windshield sealant because I do not intend to ever remove it.
spankybear
977
WA
So far I have ordered some foam strip from Mcmaster Carr. Its as close as I can find that matches the stuff called out in the TM. I ordered some copper crush washers also from McMaster Carr. I agree that there could be a leak from the screws. I picked the copper crush washers because 1) they should make a good seal between the surfaces. 2) stronger than plastic and 2) they have a smaller outside diameter than the head of the screw. Theory is I can get some type of sealant under the head of the screw. Maybe overkill but I DO NOT WANT THIS TO LEAK! I did a lot of rust repair.
I am also going to install a windshield. I have been looking and I think I am going to use 3M Auto Bedding and Glazing Compound around the gasket where it meets the body. Again I do not want leaks. But I do want to be able to replace it if needed. Big flat up and down windshield is gust screaming to a rock crack. Links to st stuff I have ordered .
I am looking around to to see that type of sealant people have used on the around the edge and screws. I would love to use the stuff called out in the TM but it's a pain. I even used the stuff at work but unlike what Suprman used it comes premixed and frozen at -60° F and needed to be used within 2 hours.
Badmiker
Shanghai, China
Anyone actually just patch up the hole with a new steel blank welded in? Like bodywork. I've done it with removing an aftermarket sunroof on a VW. Patched, skimmed, primered and painted. Just thought it would be a good way to eliminate the honking great hole in the roof.
Sent from my Mi 10 using Tapatalk
HotTubTimeMachine
15
Anchorage/Alaska
My cover was leaking through the factory flat sealing strip. The way I parked was allowing a small pool of water to build towards the back of the cab and that is where the original real was overlapped and allowing water to go between the seals like a labyrinth.
I went with a spool of neoprene O-ring and made up two pieces. Each either side of 4 ft diameter. One on the outside and one inside the bolt pattern.
Seals great but highlighted other leaks in the cab
jkcondrey
141
Rutherfordton, NC
I used 1" thick, closed cell phone tape about 1" wide as well. Ran that all the way around and overlapped with a bit of silicone in the gap to ensure seal. Put a dab of sealant on the bolts as well. Has not leaked since. Incidentally, it had the original 1/4 thick rubber strips with matching bolt holes in it, that leaked terribly.
Third From Texas
6,663
Corpus Christi Texas
I'm planning to welding mine shut and doing some filler before I sound/heatproof the cab and build my upper console.
Kemper
Centerville, NJ
After lots of research I used 3M 740 UV. Paintable sandable and extremely durable.
I "wet set" into a bead then sealed the recess around the cover as well as the new 316 ss bolt heads.
Blownaway
14
Hawaii
What size bolts will work in the factory holes? Mine is missing, I need to chase the holes with a blind tap and buy some bolts and make something work. Thanks
Ronmar
8,207
Port angeles wa
Beeswax and bunny farts…
if the cab is level, you don’t really need any as the gutter will drain down the center of the windshield before the water gets high enough to go over the lip. But if the cab is slightly tilted to the rear the gutter can just barely get deep enough to surmount the lip.
Mine of course with blown airbags(lower at the rear) would drip when it rains. mine had a strip of peel and stick weather stripping overlapped ~6-8”. Of course the bright light who did this install left a 1/2” gap between the overlapped strips. And if course this gap was at the back where the water is deepest worst case. The wx strip was in great shape, so I left it and added a little sealant to fill the gap tall enough to match the height and compress when the cover was installed And let this cure. Hasn’t leaked since…
Any sort of D profile wx strip, just taller than the inner lip should work as long as it forms a continuous ring That will compress and seal when the hatch is installed. A bead of sealant would work but you need to be really consistent with the bead height. A small bead of waterproof spray foam that expands above the ring would also work, You could also probably use rubber or silicone hose(DIY O-ring), the wx stripping is just easier to install. I would put the overlap/joint from the weather strip at the front/gutter drain, where the water should always be the shallowest…
