Thank you! I haven't looked long, but the underhood mounts seem to be rare and expensive.Mine will not. I’m still looking for a reasonably priced under hood mount...
Found pics at g503... https://forums.g503.com/viewtopic.php?t=194135Anyone got a picture of where this thing mounts?
That's the early one, I thought it'd fit. The mount is for the "3.5 ton" jack that was made much later. That absolutely won't fit under the seat... I'd like mine to fit there too, now it rides on the floor behind the driver when I'm out, just in case.The one that came with mine was in a bag with all the tools. Fits easy in the box under the drivers side rear seat.
high lift location on mine.When I purchased mine it did not have a jack at all so I opted for a High Lift jack that I mounted on the bed divider wall then I keep a jack stand under the back seat so that I can safely work on the HMMWV as I don't get under the vehicle utilizing this type of jack.
Like it... if I had the bed seats I would likely had mounted something like that as well, but since I don’t I mounted inside cab to keep out of weather.high lift location on mine.
