- 220
- 99
- 28
- Austin, TX
Truck starts and runs solid. But when I let off the throttle to turn a corner or such, the engine rpm drops below idle and sometimes dies on me. Not a fun time when turning so I generally keep the throttle pressed a bit.
I looked through the forum but only found the this thread that says the right way to diagnose/fix this is to pull the injector pump and send it off for bench testing. Is this the only fix or am I missing something really simple first?
NHC 250 fuel problem
My M932 has gotten to where when you rev it up to 1500-2000rpm and let off the throttle quickly it will sometimes die. I've changed the fuel filter, checked for fuel leaks, checked the fuel shutoff, checked the emergency stop, and cleaned the screen in the pump. I'd did do a little reading up...
www.steelsoldiers.com
