TOM R
- 93
- 28
- sewell n.j.
changed title to build thread , I can do a seperate thread on the m1114 roof when i get there
It will be ok lolThat will be a heck of a lot of cutting and aligning and welding.
Ill deal with that when i get there, i may not even use the hatch holeSo...what are you going to do about a turret support ?
I would deal with it now, while the roof is off....Ill deal with that when i get there, i may not even use the hatch hole
I measured my 998 windshield frame at 80" opening on the roof is 87"Speaking of the M1114 roof, did you happen to measure the width?
I'm trying to figure out the width to the side bends, the width of the side bends and the width at the outer edge of the side bends, to use that info for an AN/TWQ-1 Avenger HMMWV 2 man aluminum roof.
Nothing yet, I also need to know exactly where to place the sponson to drill holesDid you put the spacers between the sponsons and fenders? Or just a strip of rubber?
