vtach
- 5
- 18
- North Dallas, TX
Has anyone installed an electric winch on their 2.5? Any PICs or recommendations?
Specs totally depend on the pump... A VTM can range from .7 to 7GPM flow to 700-3000 PSI, it just depends on the model. Thus far I have seen 4 diffrently spec'ed pumps used on various 5 tons which avrage around 4gpm / 1400 PSI. If you try to put one with higher flow PSI it sounds like the gear's getting ready to eject it's self at about 1700 RPM and it eats the shaft seals right out of the pump.What's the flow rate and relief setting of the LDS pump?
A PTO pump would work wonderfully for the application...I suppose a PTO on the transmission could do for the pump on a hyd. winch? Would it be enough, or is that what you are already saying would be inadequate?
