Alternative radio mount solutions for m35a2
muthkw25
777
Canton, PA
Im wondering if anyone has mounted the radio in an alternative location other than under the seat on the passenger side of the m35a2. I have two spring seats in my m109a3 and I would like to mount a rt524 between the seats if possible. I'm considering building a mount but wonder if the 939 series mount would work with some modifications?
Dunkeye11
Fairfax, Virginia
So I have seen some verticlly mounted radio solutions you could try that and test how well the 524 works like that but might get dirt in its little fan
a PRC77 does have a vertical mount I have seen but it’s non powered
muthkw25
777
Canton, PA
I was planning on doing a 2 tier radio mount. First one for the Vic 1 and 2nd one for the rt-524. Thought it would be nice to keep it off the ground. I guess if dirt gets in then I'll have to clean it more often. Just trying to look at some alternative methods because I'm running the spring seat on the passenger side.
muthkw25
777
Canton, PA
Yea I was just changing over to a VRC12 series radio in mine selling the sincgars and I think the 524 might overheat on the floor of the deuce I’m gonna put my 77 there instead
I was thinking about buying one of the hmmwv rt524 mounts and then adding some support brackets and see if I could get it to work.
muthkw25
777
Canton, PA
That could work well they are all aluminum I think
You would have to shrink it because most are wide enough to fit an Rt524 and the r442
If that's true then I could cut it down to fit the rt524. I'll get some measurements and find out how much space before buying anything.
jeffhuey1n
SMSgt, USAF (Ret.)
1,664
Laramie County, Wyoming
I’ve mounted my RT 524 in the bed of War Wagon. Unless you’re building a gun truck, it might not work. That being said, I’ve seen radios mounted in the bed of the M35 underneath one side or the others troop seats. Having a soft top in the back would definitely be a good idea. Minimizes chances of wiring/radio shorts.
muthkw25
777
Canton, PA
Very slick design. When I build a guntruck in the future I will def mount it in the bed of the truck.
