theanimal
- 1
- 8
- Tomball/Tx.
Ok so I finally got around to working on my m923a2. Changed the dip tubes (stainless), put all new Parker push lock fittings and lines from tank to lift pump and from tank to return on injection pump. New lift pump and cleaned tank completely. Also new fuel filter.
Truck will crank with stating fluid and stay running as long as you keep it revved to about 800. It will also drive around but has no get up and go. As soon as you let off the pedal and push the brakes the truck idles down until it dies. It won’t crank back up unless you spray stater fluid in the intake.
I broke all the lines on the injector pump while it was running and I get a strong spray from each one.
pulling my hair out over here
