Unluckyfett
- 2
- 3
- Fingerlakes NY
Hi,
I want to start off with thank you for all the information everyone has shared in all the threads. I know there are tons of threads about alternator problems and the stickys have made everything much easier, but I need some help understanding where I'm going wrong.
Long story sort of short:
Bought M1008, gen 2 light not lit on bulb check. Dash lights didn't work. Cleaned all dash contacts. Fixed dash lights. Did doghead starter solonoid mod, Found fault in gen 2. While rebuilding gen 2 broke case. Bought new isolated ground 27si. When installing new gen 2, tightening the nuts, the ring terminal turned and caused direct short (rookie move). Direct short let the smoke out of gen 1. Rebuilt gen1, no regulation. 32v across both batteries 17v on front battery 14.5v on rear. Rebuilt gen1 second time, same result.
Is there anything external that would cause the alternator to not regulate?
At this point I'm going to buy a second new isolated ground alternator and maybe I can eventually figure it out.
If anyone has any thoughts please feel free to tell me, at this point I'm assuming I've screwed up rebuilding it.
Thanks for all the help
