HDN
- 5,375
- Finger Lakes Region, NY
I'm pretty sure the little valve stem grommets on my M35A3's rims are all shot. I've been planning on disassembling the wheels to clean the rims and replace the O-rings and the little grommets, but I have no doubt at some point that the grommet will fail again and I will have to take the rims apart - again!
Has anyone figured out a way to do away with the grommet all together? I was thinking about welding a fitting right to the rim where the valve stem is supposed to go. I've also considered tubes, but I'm not sure how I would go about installing them in the rim, like if I'd have to drill another hole for the tube valve stem. Thoughts?
