Curious about best apparatus to put in 3.07 middle gears
Reworked LMTV
1,525
1,188
TN
Hi Guys,
Well the axles went in for balancing yesterday. Tiger Tool helped a lot. If you use one you must take the zerks out first. They get destroyed.
I need to drop in the 3.07 gears. Just curious about using a gantry and chain hoist vs. engine hoist vs?
I am putting in a locker at the time. Count the number of turns and mark the star nut position? This is what I have seen.
Suprman
705
Stratford/Connecticut
The guy that sold me the locker said to scribe mark everything before taking apart to install the locker and then put it all back together using the marks. I didn’t personally do it I had a local driveline shop do it but it came out fine that way.
Awesomeness
1,520
Orlando, FL
Did you stabilize that massive chunk with anything?
Nope. It sat in the saddle/dish on top of the jack. One person kept a hold of the gears, and one slid the jack.
It would probably work better with a transmission saddle on the jack, but it never felt overly-precarious. (And I'm not the type of person to do blatantly stupid things that are unsafe. If I had felt it was going to end poorly, I would have just gone and bought the transmission jack.)
Reworked LMTV
1,525
1,188
TN
I am assuming you did a 4x4, not the 6x6. The 6x6 chunk in the middle is massive.
ramdough
1,730
Austin, Texas
I unloaded an intermediate differential from an F250 once. With three people, it was more of a controlled fall.
For my install, I plan to have the bed off and then do a chain fall from above. Maybe use a motorcycle jack from below.
