- 25
- 7
- 3
- Valley Cottage New York
Thanks for the reply, it gets worse. I just popped the intake housing off it to look at the blower and found a powdered substance in it. The air box has tacky black oil in it with no evidence of the powder. Not much oil in theair box though, but enough to raise questions on if this engine was re built or swapped out for a re built in whatever it came out of.That block should have been hot tanked during overhaul and should be sparkling clean inside.
Yup that is a take out. The flaky paint is a dead giveaway. Someone pulled it because something is wrong with it. Consider it a core.
What's it worth as a core? $1500? It turns 360Yup that is a take out. The flaky paint is a dead giveaway. Someone pulled it because something is wrong with it. Consider it a core.
Less than that, maybe half since it's a non-running core. Someone on the flebay is selling a complete engine for $1250. There's also another person selling 6 engine/transmission/radiator sets for $2k each so there's your price points. If you don't plan on using it why not try to start it up and see if it runs to increase the value. Just a thought.What's it worth as a core? $1500? It turns 360
It's a total gamble, who knows until you try it. Make sure you remove the valve cover and check the injectors. If they're stuck the engine will run away on you.I was thinking just that same thing. It's worth a shot and may run fine right?
