- 483
- 33
- 28
- Ahwatukee, AZ
A little background on the truck first to start my journey of rebuilding this M1084A1 truck. The truck came out of Joint Base Lewis McChord, WA. It was assigned to the 5th Battalion, 3rd Field Artillery. It has the CAT C7 Ascert motor. Going through the manuals that are available, they do not list the Hiab 133 ATD-2 crane that is on the truck. Hiab brochure on this crane states they are specifically developed to handle missile and rocket canisters. The facebook page for 5th Battalion, 3rd Field Artillery shows a few of these trucks in use for this purpose, and also loading the M1095 trailer with the canisters.
My journey has begun to identify the broken parts on the motor (Fuel filter base), drain water from the turbo, and inter-cooler, and change out the oil and filter. The oil cap was left off, and top of air cleaner was not on the vehicle. I checked inside the head, and the water did not make it all the up there except for a few splashes of water possibly during transport. The motor turns over by hand easily. A light coating of ATF fluid was put on the valve guides for any water contamination.
Next will be to change out the cab, hook all the airlines up to the dryer, and install missing or damaged parts ( CTIS valve body/controller, drivers door, quarter side window). I am trying to locate the manual for the Hiab 133 ATD-2 crane. If I could use the crane with the manual pump, it does have the length to lift off the cab. Otherwise I will be hiring a crane to come out and lift both cabs. Here are a few photos of the truck and the start of my rebuild journey. A special thanks to Matt Lane for the assistance with getting the Cab, and helping with unloading the truck from the transport. And Alex Vinson for parting with the cab, and Tim Filson who is helping with parts for this rebuild.
