Tatersalad812
soooo... i bought my 4th and 5th generators this week. both are mep004a and I started going through one to get it running after fighting with everything under the sun i finally got fuel to the injection pump... i found the solenoid on top of the pump to be stuck in the running position.... not sure how thats possible but hey i always get the weird stuff. The rack in the pump was also stuck in the run position so i moved it a couple times and it freed up. i still for the life of me cant get the injectors to get fuel. i cracked the lines at the pump and i get notta. what am i missing? should i pull the pump and rip it apart and clean everything? it doesnt look as simple as my mep002a pump. any tips or tricks gettting deep into the pump? oh and the glass ball is clean as well as the filter on the pump inlet. iv got fuel in and out of the pump but nothing at the injectors. ive got the throttle at half. thanks in advance for any and all help
