lonesouth
- 29
- 28
- Tallahassee, FL
I just moved to a new house and have not had time to run a new dedicated circuit for the generator. What I do have access to is a 3 wire dryer circuit that was abandoned. When using a 3 wire circuit, which of the below is the best solution? I will install an interlock on the circuit.
1. connect the bonding strap in the generator and use the single neutral to carry the ground
2. leave the bonding strap disconnected and drive a ground rod to use as the ground
This is won't be permanent, just looking for something to get me by until I get the remodel done or through hurricane season.
