That's a good idea to modernize the lighting switch and having to remember to flip it on or off to go for a ride. The chance to save the batteries... YEP, but with my luck a TICKET for no STOP and TURN lights.
BUT... I am not so sure of your wiring schematic, as I roll it around in my pea sized brain is correct. Without any control logic (even a diode proper rating) I get the impression that the way you describe it, one could turn on the lights and back feed power to the run circuit of truck. So if truck was running and one turned ON the lights, one could NOT shut off the truck. Now than can't be good either. ither, or maybe it is?
Correct me if I got that logic wrong.
Driving a HMMWV is like no other, CAMO
OK I am sure I am going to get some hate from the purists but here goes.
At the light switch, 22A is the stop light feed to the turn signal switch, 75A and 75B are the stop light switch, and 15A is the main power feed to the light switch
So I cut 22A, and both 75A and 75B away from the light switch connector, connect 75B directly to 22A then connect 75A through a fuse to a tap on 15A
VOILA 24/7 brake lights
467A feeds the turn signals and horn, I cut it away from the light switch and connect it through a fuse to 29A the switched hot side of the master start switch, now you have switched turn signals and horn when in the run position, and no there is no chance for backfeed,
You could also tie 467A and 75A through a single fuse to 15A, then the turn signals including the 4 way flashers would be available with the ign. off, it is just not the way I did it.
(note the schematic shows 476A spliced and becoming 467B, turn signal and 26A, horn outside the light switch but as I remember 26A is connected inside the light switch connector and I had to cut it loose and tie 467 and 26A together at the fuse)
AND of course ALWAYS solder ALL connections and use jelled heat shrink when ever possible, crimp on connectors are for lawn mowers......
Also leave enough wire at the light switch when you cut them to always be able to reverse anything you do and seal all loose (cut) ends
![BRAKES.jpg BRAKES.jpg](https://www.steelsoldiers.com/data/attachments/563/563007-83e0737a80b2742b6bc95a5a678627a3.jpg)
This is how I did it, as you can see if you tie 467A to 75A and just use the single fuse the turn signals and 4 way flashers and horn will also be hot all the time, ignore the numbers on the turn signal switch, I did not feel like building a component from scratch and I left out H which is inconsequential to this mod.
Also do not "bury" the fuse in the dash so you can get to it if needed, a breaker could also be used, 10A should be plenty..
