jblack6527
- 3
- 18
- Weaverville NC
I've searched here, and just on Google for this and can find lots of guys with different problems, but none like this.
If I've missed one, please link me to it.
I have a new to me truck, and when you turn on the Right hand turn signal, everything operates as intended. Regardless whether headlights are on or off.
If you turn on the left signals, with the headlights off, every light on the outside of the truck flashes, including the headlights.
If you turn the signals on with the headlights on, the light on the signal switch comes on steady.
I've been cleaning grounds on the left side of the truck, and have gotten both light housings, and the flasher cleaned but so far have had no luck. I don't get a lot of time to work on it with the rain every day.
I also swapped out the three lever switch, and flasher with known good(new) parts to no success.
Does it sound like I'm on the right track? Any other ideas?
I have a multimeter but other than checking for voltage I'm not very handy with it.
