jimm1009
- 70
- 48
- Louisville, KY
I went on line last night to one of those web sites that has a GM mechanic
that is available for questions.
I was told that the engine driven fuel pump is supposed to have 7 to 11 PSI output @ idle.
Does anyone know if this is true?
I can't find a reference for that in the -34 TM or in the Chevy factory manual
so I am not sure.
I am troubleshooting white smoke with a properly timed injection pump and new filter. I had much more smoke before I change the filter but still have some and the pressure being too low will also cause white smoke but I can not find the reference for minimum pressure into the intake line for the injection pump.
I have 4 PSI @ idle with some white smoke. The pressure actually drops from idle to about 2 PSI @ around 1200 RPMs estimated.
As a side question, has anyone opted for an auxiliary electric pump and has this helped your CUCV? If so, do you still have info on the pump?
Jim
so I am not sure.
Jim
