McSpeed
- 293
- 63
- Palmer, AK
Noticed my otherwise flawless fan clutch is weeping fluid. I've found a possible rebuild kit around $200 and noted these things tend to be out of stock or stupid expensive in the $500 plus range, When I replaced the water pump I put a close fit o-ring from in my shop in the front nose where the hose bolts in as the original was cracked and dead. It clearly didn't work long term. I took the truck on a very long ride last week that likely finished it off.
So...does anybody know where to get just the o-rings? And or - let's talk about a 24 volt electric fan. Plenty out there. Should be room to mount it in the opening once the stock fan and clutch are gone, I just hate doing that if I could come up with $20 worth of the two front o-rings and be done with it.
Thoughts?
Thoughts?
