Air leaking from brake exhaust port
BeaufortFire
Beaufort/NC
I've spent a long time searching the forums for a similar problem. But here it goes. Have a LMTV that when aired up there is a constant air leak from the brake system exhaust port in the rear and when you pull the supply line to a front brake chamber sir leaks there too. Can you guys point me in the right direction?
Ronmar
8,167
Port angeles wa
Which brake system exhaust port? There are several back on that crossmember. A picture would be valuable. I just did a rear brake component explanation video yesterday that might also help you...
