A few mods done to my 1078
Juanri23
Spain
Hii, you're absolutely right. I'm at that point now. Can you explain to me in a little detail how you connected it? So I understand for the key to work you have to have the button pressed to turn on with a key? Or is it the other way around?
Andyrv6av8r
455
Spartanburg,SC
Not sure if I understand you correctly but the key switch has to be turned in the On position before I start with the normal push button.
