So here is what I have done to clean my injectors. I an not saying this is the way it is supposed to be done. I am just describing what I did and what seemed sensible to me.
your experience may vary. I didn't find much info or photo's of how the injector look and come apart and so I decided to share my photo's
First I cleaned the entire injector in 99% alcohol and stuck it in my ultrasonic cleaner on 75 degrees for 20 mins.
then I took the injector out and loosen the two halves a tiny bit and cleaned it for another 20 mins in fresh alcohol solution
then I opened the injector all the way, taking care and paying attention of how the pieces would come apart
here you can see the two halves bottom part with nozzle nut, heat shield, pintle nozzle, intermediate plate, pressure spindle and the top part with pressure spring shims and high pressure inlet
here are the parts
from left to right ,heat shield pintle nozzle intermediate plate and pressure spindle
the top half with shims and the pressure spring to the right
Here it took the pintle nozzle further apart and you can see the needle valve.
I stuck those bottom half parts in the ultrasonic cleaner again. and then cleaned them thoroughly with q tips and kim wipes. and put them in the ultrasonic cleaner again.
I used fresh alcohol every time in a plastic quart container with lid.
I then lubed the pieces with Howes diesel lubricant and checked for a smooth fit.
finally I reassembled the injector noting carefully how all the pieces go back inside.
It's pretty straight forward.
here are the parts
