flashbucks
- 73
- 18
- Albuquerque, NM
While using our wrecker to rearrange the yard, we lost all hydraulic pressure to the crane. Yes it is in gear, yes the power divider is in the forward position (drive shaft is turning all the way to the pump) . Everything was running great then the rotation of the crane started to be a little "jerky" under load and finally all hydraulic pressure was gone. We were low on fluid but adding fluid did not help. Any thoughts? Thanks, Gregg
