Monkeyboyarmy
- 193
- 63
- Kingsville,Oh.
Replaced the fuel pump?? Do you mean bypassed the piston pump at the front of the engine? Does it just push through the check valves of the original pump?
The original alternators are pretty good as long as you don't "shock" the system by trying to charge dead batteries or even when you slave another vehicle. Typically the regulator burns out which is replaceable. The 6 little screws attach it to the rear of the alternator. It is not serviceable but occasionally the large resistor is blown out and replaceable. There are US made and Greek made. The regulators are the same except for the outer diameters are slightly different. The 60 amp alternators from the 60's to present are interchangeable if you happen to find a good used one somewhere.
I'm sure everyone would like to see pics of your truck.
