Bsmith720D
- 3
- 3
- Napoleon Ohio
So I’ve been having some issues with the brakes on my 1971 Deuce and I’m in need of some help or advice. over the course of a 2 years or so, I went through the whole truck and rebuilt or replaced the wheel cylinders as needed during my regular maintenance. i went through and took an air hose and blew out the lines to get all the junk out and replaced the rubber lines. I also bought a new master cylinder since the old one was pitted on the inside. I had the brakes lock up on me shortly after and figured it was the air pack. So I decided to buy a new air pack instead of rebuilding it. I went through and bled all the brakes last year and thought I was good to go. Shortly after I parked the truck in the barn for the winter. I just recently got it out and ran it for about 10 miles. I pulled it into the drive for about 15 mins (still running) and then headed back out on the road and only made it like 50 feet Down the road and knew right away that the brakes locked up. so I turned around and pulled into my drive. When I first got in the truck and started it, I felt the brake and there didn’t seem to be any pedal there. After driving it for a couple miles, the pedal firmed right up. Now the pedal is super stiff. Like stepping on a brick and the brakes are stuck out. I climbed under the truck and took the plug off the back of the air pack and didn’t feel or hear any air coming out the back of the air pack. I then loosened the fitting from the master cylinder to the air pack and it didnt. release the brakes. So I Then loosened the line on the top of the air pack running to wheel cylinder and the brakes released. I can’t figure out why the brakes keep locking up. It’s a brand new air pack and master cylinder. The little hole in the new master cylinder was way smaller than the old cylinder so I drilled it out to .030 thou. before I installed it, Cleaned it all up and installed it on the truck. I also went through and made sure the adjustment was right for the brake pedal. Can anyone send me the right direction on what to do because I’m lost.
