tgtaylor64
- 5
- 18
- Florence, SC
While my son was backing a trailer, the PS went out. Expected to see a leaking hose but all hoses and belts under hood looked fine. Some PS fluid was dripping from the bottom of the reservoir but that was due to foaming and it was coming out the top. Fluid level was good. Brake system was good and full of DOT5. Figured it was due to a failed pump. Just put a new one on yesterday (with a new o-ring on the metal line that goes in the rear) but nothing changed; still no power steering. Nothing is whining and it does not appear to be foaming anymore. I had used ATF before but was out so I filled the reservoir with new GM approved PS fluid. Could that be part of the issue? Should I drain it and put in ATF? Anything else to try?
