Reworked LMTV
- 1,566
- 1,214
- TN
Just wanted to do a quick review of the FMTV/MTV sway bar bushing upgrades available from Awesomeness/ Guido. The install was fairly easy on my M1088. One large bolt on the passenger side gave me grief, so I cut it off. There are essentially 3 pieces that need to line up, so it would be best to put the smaller 4 bolts in the bracket before trying to put back on. On the 5 tons the level of the grease fitting is different. I used the slit in the bushing to align the grooves in the bushing to allow grease to get around the sway bar. The drilling of the Zerk fitting was easy, and a nice high-quality drill bit is included. No tap is needed.
1st drive showed a significant improvement in reduction of rear body roll. In fact, the confidence going around corners is greatly improved.
Of note is the upper small bushing which attaches the sway bar to the frame. Really this needs to be replaced too. Once this is done, the improvement will be even greater. Guido states that he will be working on these fittings, but it may be a while.
I was not paid for this review, nor was an incentive given.
5 Stars-well worth the time and money
PS I am also doing the bushings on my trailer and will report back on those. He makes those as well, but they are different.
