Bolt in a Tire on my M1088 / LMTV
20,738
So, I am smart enough to not just yank the bolt out... On the other hand, it might be a short bolt that hasn't punctured the inner core of the tire - and the more I move the truck around - the worse it might get.
This CTIS plumbing is new to me. Not so sure I want to call a tire repair shop that might not know how to work on a CTIS rim - and have them end up breaking something that isn't broken...
I have a spare. Could swap it out and take the tire somewhere. OR, maybe I could be lazy and have a professional do the job. Just soliciting opinions here. Can / Should it be patched on the inside if the bolt went through? Plugs? Are they appropriate?
Forward rear axle on the driver's side. Picture below:
snowtrac nome
142
western alaska
if it is a leaker get a safety seal plug kit i got mine from amazon you will want the truck plugs. I had the same thing in my rear took 5 minutes to do a nice permanent repair. The safety seal brand plugs stick and seal like nothing else right now i have 4 in my sidewall as a badar repair waiting for the rain to stop so i can change it out and stay dry.
20,738
Sitting as it is right now, using Dawn in a spray bottle - I get no bubbles. CTIS stabilizes and the red light stops blinking when my air tanks fill up. I have an air leak of some sort that seems to be dead center under the cab. I hear it hissing when I turn the truck off...
20,738
Replace that ancient Michelin!!
I have 6 more just like it... Five on the ground and a spare. All in about the same condition. Tread doesn't seem half bad... It made the trip up from Sarasota Florida and road as smoothly as a 1088 and empty trailer could be. I was hoping to get another year or so out of them? Should I be looking at date codes? Like the "sell before" date on a loaf of bread?
snowtrac nome
142
western alaska
i would s
till have a plug kit handy before pulling the screw out some times they seal up pretty well. i would not drive it the way it is i picked up a nail on a job site once i didnt know it was leaking and wasnt in run flat i had a side wall blow out 45 minutes later. it may not be leaking now but t can start at any time.
20,738
i would s
Thanks snowtrac nome!
I figure a plug kit in the truck after making the attempt would be money well spent. As a teenager, I worked weekends in a tire store. I learned the concept of following the hole if there is one - rather than being a DA and punching a new hole in the tire cramming a plug in "any old way". That is how belts slip and big knots pop up on repaired tires...
THANKS for the advise!
20,738
I would be amazed if that is not through the belts.
I see a patch in your future. Maybe your spare is a better and can swap around after repair.
Thanks juanprado. My spare has about the same tread life as what I have on the ground now. I thought the tires looked pretty good. Not new by any means - but decent. No dry rot. No cracks. I guess a spare in the rack with a plug is better (safer) than a plugged tire on the road...
20,738
Turned out that the bolt was through and into the tire, but a "MonkeyGrip" plug has been holding steady for about two weeks now...
NEW QUESTION:
Spare Tire sitting in the rack. CTIS connection is just hanging there because there isn't a connection for it... My spare is FLAT. Should it hold air when sitting in the spare rack? Logic says a flat being replaced by a flat wouldn't be very attractive. I mean I know that Central Tire should inflate it - but is that right?
