So I am working on a 1992 hmmwv. Put on a dual voltage alternator. Not charging, found no 24 volts to ign post. found the kds box was bad. replaced that with a Nartron box, now the wait light works and i have 24 volts to the ign post. still no charge. I have no volts out of the a/c tap wire or post. should i have volts going to that or coming out, not a bunch of info. we got used newer alternator and robbed the regulator off, still not charging. this was the original problem. Cant use the alt due to it has a serp pully and mine is v belts. any info or if there is a way to check the alt to see if its bad. For wiring i have large wire to main stud on alt and the ground wire from truck to ground stud on alt, and the ground strap to same stud and to the stud on bracket. then wire from truck to ign post, i have the other wire capped off. and the tap wire going to the a/c tap. did not put anything on the 14 volt to test yet. was told if you ground it it takes out the 12 volt side. dont want to fry anything. any help or info, thanks chris
