that's what i thought. i am getting good flow so probably doesn't have a thermostat installed. anyone know a stant number or some other crossover so i can just go to the parts store and get one? what temp thermostat should i get?
Thanks
Had same issue with my 803a. Wouldn't come up past 130 degrees after 1 hour.
A Diesel engine will run at minimum temperature for a very long time with no thermostat or a stat that is stuck open.
Installed the Murray Mu55358 and gasket # 2138. Now runs at 180 degrees which is good for summer operations.
Oreilly's Auto Parts had them both in stock.
I buffed the housing clean and use a very light coating of Indian Head gasket shellac on both sides of the gasket to insure a good seal.
Your upper hose should be noticeably hotter than the lower hose.
Prior to installing the thermostat, both hoses were equally just warm......that indicates either a stuck OPEN thermostat, or a missing thermostat. Mine was missing.
