Hello, I’ve been stalking and lurking for a while now and finally have a reason to post and ask. I just acquired a 1996 1078 with transmission issues. I’m hoping I can sort them out before having to drop the transmission. Today I discovered some corrosion in the lower connector for the control panel. Does anyone know if I can get a new connector and new pins and simply re-crimp and put a new plug on it. I probably don’t need a new plug and could just put some fresh pins to get things working.
Also while I had it off I peeked in the control box to see if I could find anything weird in there and found a burnt spot on one of the boards in there. It appears to be a burnt mosfet. Does anyone have enough experience with these to know if they’re re-buildable? Worth rebuilding? Or know where I can find a cheap known working used one?
I think mine is a WTEC 2 system.
Thanks!!!
Casey
Thanks!!!
Casey
