DanielC
- 1
- 3
- Varnville sc
Hi everyone, thanks for accepting me in the group. I recently bought my first deuce. I believe its a 1970 am general m35a2 with turbo hercules multifuel motor... the truck runs and drives but the brakes are sticking so im working on that... its hard to start cold so I have to give it one little squirt of starting fluid... the hydraulic head has had new o rings installed because it was leaking diesel into the oil... thats fixed and has fresh oil... oil and fuel filters were changed and bled... in tank pump doesn't work so I had to pressurize tank to bleed... truck surges between 400 and 1000 rpms until warm but will run and rev up all day with no problem... but when driving it around the yard under a load for a couple mins it will just shut down like someone pulled the stop lever or motor seized but it will start back... the generator regulator is bad but I have a new one otw... meantime I have to charge them with my truck one at a time after I drag them down starting it... solenoid on starter acts up when hot too... won't magnetize and close the contactor.... cools down and it will work again... would the pump or hh going out cause the shutting down under load issue? Thought I locked the motor up first time it happened... seems hard to turn over soon as it shuts down... thanks in advance
