290smallcam
- 36
- 28
- peru,indiana
I thought all 3 axles had some sort of locker installed already? Thought of buying a M 1083A1 instead of a M35A2, but if I cant have lockers in all 3 axles im out?
Their is only one locker and it is inside the Power Divider Box. Rudimentary example..... this box is a differential mounted sideways. Think of it as a differential sideways with a driveshaft attached in place of axle shafts.. one driveshaft goes to the middle axle and one goes to the rearmost axle on the 6x6. Like any other differential it allows one axle shaft (drive shaft in rudimentary example) to rotate more than another .... and this one has a locker on it. This differential allows the middle axle and the rear axle to rotate different speeds from each other. When Power Divider's differential is locked... the middle axle and the rear axle turn at same speeds in same way a locked differential in a typical axle turns both wheels the same speedI thought all 3 axles had some sort of locker installed already? Thought of buying a M 1083A1 instead of a M35A2, but if I cant have lockers in all 3 axles im out?
noting complicated.... it just the better way to do a 6x6 . Particularly one that goes offroad. Tag axle only as second one in 6x6 does not help beyond weight carrying. Full time equal power to two rear axles in 6x6 increases wear (same as driving in full 4wd all the time would in a regular 4x4) and disconnect set up where you have either tag axle or lock in rear one so then both power requires you to stop before activation to prevent shock loads etc. that breaks things.why to complicated !!
is there a thread on this? I thought air lockers were not actually coming.that being said Bryce Wiaslek is almost done with his axle conversions.... they will replace axles in a 4 wheeled FMTV and have air lockers in front and rear along with slight better ratio options than what is available now.
it is NOT a locker alone.... it is a set of whole different model axles to replace the FMTV axles. The set comes with an OEM air locker already installed.is there a thread on this? I thought air lockers were not actually coming.
What is the cost on this?it is NOT a locker alone.... it is a set of whole different model axles to replace the FMTV axles. The set comes with an OEM air locker already installed.
Bryce is not on SSolders.
you would have to ask Bryce thru facebook. Ive no clueWhat is the cost on this?
Ugh I don't use FB. Too much data misuse.you would have to ask Bryce thru facebook. Ive no clue
Bryce Wasielak
Bryce Wasielak is on Facebook. Join Facebook to connect with Bryce Wasielak and others you may know. Facebook gives people the power to share and makes the world more open and connected.www.facebook.com
Yeah I left it long ago for same reasons but my boss started using the message feature for employee wide communications for a while and that drew me back. ended up finding some good LMTV groups after. Some refuse to come here based on passed issues..... others do both (most)Ugh I don't use FB. Too much data misuse.
