Level wind for 10k Garwood?
MDdeuce
35
Whiteford MD
Does anybody know if a level wind (or similar) assembly was ever made for the 10k Garwood winch used on the Deuces? I know some of the 20k winches, and most of the larger ones have them, but I’ve never seen them for the 10k ones.
The little bumper plates on the sides of the 10k winch are fairly useless and whenever I use the winch the cable all bounds up on one side and I always spend way more time fixing the bird nest than anything else. Plus I always thought the level wind looked neat.
I’ve seen a number of threads about putting a whole 20k winch on the deuce, but nothing addressing just the level wind topic.
cattlerepairman
3,465
NORTH (Canada)
Sent from my SM-G950W using Tapatalk
Jeepsinker
467
Dry Creek, Louisiana
Actual pictures? Or just images from a TM (which then turned out to be from a 5-ton with the 20K Garwood + level wind) ?
(-> read that thread linked in post #2)
Actual pictures, both of one equipped on a truck and another unit mounted on what was clearly a 10k Garwood. The visual differences in the two winches are clear to the trained eye.
