- 1,507
- 1,175
- TN
Thank you kindly!Patience is key here.
A (Very) Small good quality drill.
Drill into the brass around the broken hardened tool.
Then Drill carefully close to the thread of the fitting.
Work the broken pieces out.
On reflection, I would, (After looking at the pictures once more)
Drill all round the Brass fitting close atop the thread.
If that cylinder has no spring it, I would dissemble it and carry out this careful procedure on a bench under good light.
Perhaps then clean up the threads with a tap.
Or, Drill next tapping oversize and re-tap it if needs must.
There will be fittings to suit I'm sure.
Post up how you did it. With pictures,
Good luck.
Yep, removing the rear can be deadly.just reminder.... spring can kill.... make sure you know how to properly do this if spring is an issue; requiring removal If so..... just get a used complete can or a new one.
Actually that tool or quite similar is what is broken off in there lolBe safe but this is the tool to get out pipe and fittings. Never found better even with all the tools I made. One of these saved me 180 MW one time.
Drill a straight hole and stick it in and turn it. It cams locks on the inside, works good.
Internal Pipe Nipple Extractor Wrench.
Personally I afraid of those brake cans and would just replace it, see all precautions and stories here in Steel Soldiers.
Thoughts on rear air brake chamber assemblies
For the LMTV community (and should be similar for other wedge brake systems): I had a noisy rear left side pair of air chambers after I shut down my M1081 LVAD. You could hear air leaking out of the spring chamber (larger inboard section that uses caging bolt). The air could be heard with or...www.steelsoldiers.com
If that true that thing is hardened and you ain't gonnah drill it out. Buy a new can.Actually that tool or quite similar is what is broken off in there lol
Not grease, use TallowThen OK. DON'T mess with taking it apart
Do as I suggested, Take your time, Careful drilling and sucking out the swarf WILL get that fitting out. Grease the Drill..(And), It will gather the swarf for you.
Yep, Good, And (As said) you ain't (Going to) drill that hardened easy out..So, As I instructed Drill Round It..It will Then come out. ( with some poking prodding and a magnet ).Not grease, use Tallow
Thank you very much!Internal pipe wrenches, or cam wrenches, are nice but you must by the higher quality wrenches. The cheaper ones end up making things worse as they have here.
That port goes to the service diaphragm. There is no spring in there. The spring is in the other half of the can which does not need to be disassembled to remove the fitting. See pictures...
The fitting you broke is where the red plug is in my picture. If you remove the clamp directly above that port this is what's inside...
View attachment 816243View attachment 816244
There is only a diphragm and push tube behind that clamp. I couldn't find my push tube that goes with that can. You just pull the push tube out. The spring is behind the larger clamp. Do not touch the larger clamp. That is a sealant/threadlocker that was applied to that fitting when installed.
Here's how I would do it...
Get a set of fluted extractors. The fluted are made for softer materials, like brass, and work much better than sprirals.
Next, you need to cage the brake can with the caging bolt. Caging the can acts as a double safety. If you were to drop the can, the caging bolt and the clamp must both fail for the spring to be released from the can. New spring brake cans are always caged for this reason as seen in my first picture. That can came with 2 caging bolts, one caging the can and one in the holder. You are only caging the can for safety. You're not opening the can. Just so I'm clear...
Remove the small clamp and set the can to the side. Remove the diaphragm and push tube. All you'll have left is a metal stalk screwed into the brake spider. You don't need to remove it if you don't want to. Use a punch to knock the broken wrench out from the inside. Insert the correct fluted extractor into the fitting from the outside and drive it in until it's got a good bite.
Take a small torch and heat the fitting while turning the extractor. The heat will soften the sealant and should allow you to remove the fitting. Wait until everything has cooled then re-install the push tube, diaphragm and can. Remove the caging bolt and don't forget to put it back in its holder for later use.
The picture is kind of deceiving, but if you look close it does appear to be a rear can.OP has a single service brake chamber as used on front wheels...
Ordered! Thank you!Internal pipe wrenches, or cam wrenches, are nice but you must by the higher quality wrenches. The cheaper ones end up making things worse as they have here.
