- 2,878
- 6,982
- West greenwich/RI
You don't need to test with the lines totally disconnected, just loosened. Things may look a little different than I described if the lines are removed completely off the injectors.
What does the plunger look like?Absolutely, the Ambac M-50 will drop right in, just need to check the timing button thickness. Everything else is the same.
I'm actually considering taking apart a good PSU ( have 1 good machine with a PSU in it ) and taking the plunger to a machine shop to see about the possibility of getting some new ones fabricated. I have 4 bad pumps that could be repaired if I had access to plungers.
Would be interesting to see what is involved in fabricating a dozen or so new ones.
Need a machine shop with precision centerless grinding capability I assume.
